Thanks man. Sorry for lack of concentration, here it is in attachment.
![](https://forum.libreelec.tv/core/images/avatars/cf/870-cfdbe43bd1bdf28bdb0544af866f69b1fb0c9eb6.webp)
LED (VFD) Displays in LibreELEC
The Coolest -
February 24, 2018 at 6:56 PM -
If i understand correct, this dtb which i extracted from Android, i cannot use it with LibreElec. So i download dtb.img file from here
I attached dtb.img file which i intend to use.
Axee I needed the Android DTB to see what the display configuration is, so that a matching vfd.conf file could be created for the device.
I'll look at it later today.
i tried, i puted this vfd.conf file you provided in /storage/.config/ folder, but nothing happend. It displays ''boot'' same as before.
Axee you need to use an LE build that has a recent version of the "openvfd" driver baked in. And of course use a DTB provided for that specific build.
I use kqszak-wrxtasy version for S912 Chipset. Which version have ''openvfd'' driver baked in ?
I'm not sure, you'll have to look around.
@Coolest I have not tried it yet because it happened yesterday, but I will let you know as soon as the results come out. Thank you.
onexzero Thanks.
From the looks of it, the vfd.conf I suggested should work just fine.
The display looks identical, and so does the DTB configuration.
Please let me know if it works, and I'll update the file in the repository to include the U5X+S as well.
Hi
I tested with vfd.conf and gxm_q201_3g.dtb yesterday, but nothing appears on the display. It just appears black. I attached dmesg log for reference. The lsmod result shows that aml_fd628.ko is loaded. I think I am doing something wrong. Thank you.
I checked configuration again..
Installed image : LibreELEC-S912.arm-8.2-8.2.2.3.img.gz ( I can't use LibreELEC-S912.arm-8.2.4.1.force.444.10bit.img.gz <-- Freezing on boot logo)
FD628Serviice running.
aml_fd628.ko loaded.
vfd.conf - /storage/.config
Anything else???
Just a word of thanks to The Coolest !
Just got the display working on my Vorke Z6 Plus following your instructions and using the device tree from post #126
Thanks!
Hi, I have a Magicsee n5 and using the files in post #389 the display does not work. The module load correct and the vfd.conf file too. But the display do not turn on. May be its a new version of N5? This is the dtb extracted from Android. The spec are s905x 2Gb Ram 16Gb Rom.
Thanks!!!!
salavert69 I'm not sure what the issue is with the N5 boxes and the VFD driver.
I had a report say that after booting up Android, and then rebooting back to LE/CE, it would work.
I don't have this box to do hands-on debugging, so it's pretty difficult to guess what is wrong exactly.
The Coolest Thanks, I will try running first android. If I can help you testing something, please tell me
Thanks !!!!!
Hi!
Which file do I use for a Tanix TX92?
Thanks!
Senseohasser Try the one attached, and let me know if it works for your box.
The Coolest No, not really. When the box is turned off, the display is off, too (that's a progress, before it was showing "boot" the whole time).
When the box is turned on, the display just shows some random "-" signs and the Pause-icon is blinking (it does not matter if a video is running or a menu is on the screen).
Any ideas?
Thanks!
Senseohasser Ok, can you try this one?
