Some Confuence Skin Settings not saving (RPi1 Model B+)
  • Hello to the LibreELEC community.
    I have LibreELEC running on my RaspberryPi Model B+ that I compiled from source.
    LibreELEC (community) Version: devel-20160412185029-r22646-g4069754
    LibreELEC git: 4069754edd2ed04f24bc11ce81c7a14064d9d8b9
    This problem is also in the current official version: LibreELEC (Jarvis 16.1-RC2) v6.90.005
    Some of the settings in Confluence do not save between reboots:
    The settings that do not save that I have found are:
    - Show Weather on home screen
    - Add-on Shortcuts
    - The first run help opens again after reboot when browsing the Video or Music libraries.
    It looks like the settings aren't being saved or recalled between reboots.
    I have Kodi Jarvis RC2 installed on a Ubuntu 14.04.4 LTS system and that Kodi setup install does not have this problem.
    Any ideas on how to fix it?
    Thanks in advance.
    Edited once, last by J876 (April 15, 2016 at 4:09 PM).
  • Have similar issues as well. I'll have to take notice of the weather on the home screen and see if that is occuring om my set up.
  • Probably not much help to you both, but this issue should be fixed in Kodi 17 / LE 8.
    Thanks for the update.
    I have been giving LibreELEC a spin with Krypton on my RaspberryPi 1 Model B+.
    So far it has been running very well until a recent Kodi crash loop (I have posted my logs in this forum).
    chewitt has replied about the status of this known bug.
    Hopefully it will be fixed soon.
    It is good that there is so many people working on great opensource projects such as LibreELEC and Kodi.
