Hello guys, I'm new to this forum and Libreelec so excuse me if I'm opening the thread in the wrong forum. I went trough a lot of information but I still can't figure out how to install Libreelec (Jarvis) on my W95 Tv box - 2GB RAM + 16GB ROM. Can someone please guide me trough the process? Thank you
Help with installing Jarvis
DoRiLoN -
December 31, 2017 at 3:52 PM -
Which version and tree do you recommend using for this type of box?
Device tree depends on hardware - SoC seems to be the S905W
Version 1 = [8.2.2.2] LibreELEC 8.2 for S905/S905X
Version 2 = [8.90.0] LibreELEC 9.0 Pre-Alpha for S905/S905X/S912
Just try to install on SD card until it works
The device tree depends on the LAN size & the RAM, 1 2 or 3 GB
try them one at a time, you don't need to recreate the image, just replace the dtb file.
as you have already read in the instructions. you know to rename the downloaded device tree to dtb.img
So I tried everything but the stupid box doesnt want to boot in libreelec. I tried the toothpick method, the Reboot to LibreElec app from google play, nothing happens. I tried every tree, too...Ideas?
Ideas?
We don´t know what You did.
1. Did You check the SoC ?
2. Android 7 on stock ?
3. Did You prepare the SD card properly ?
4. Did You try an USB stick ?
1. SoC is 905W
2. Android 7 Stock rooted
3 and 4. I only tried with USB because I dont have a SD to spare right now
Did You try every USB port - probably only one Port works
Did You try whithout .dtb file ?
Hint:
Buy a SD card
I tried every port. Should I try completely without .dtb file or with the one, which is already in the image file?
Should I try completely without .dtb file ?
Try it.
I tried it. The OS booted and now it's stucked on this screen:
https://imgur.com/a/dMdS2
Maybe 7.03 version is to old for S905W SoC
Try newer version 8.2.2.2.2
Nope nothing happens.
I have already tried various releases but all of them just got stuck at the bootscreen or dont start at all...
