Hi there, pretty sure that there was already a thread on this, so if somebody could direct me to the instructions on how to auto mount an usb hard disk drive after a reboot. At the moment it seems that I always have to unplug/plug the drive before the system recognises the drive. editing the fstab obviously does not work under libreelec, so I would be grateful if somebody could help me out.
How to auto mount an usb hard disk drive
Bully_ASP -
December 28, 2017 at 5:58 PM -
- Official Post
The OS will auto-mount the drive unless there is an issue with the filesystem. The usual issue we see reported is "unsafe eject" from Windows which leaves the filesystem in an unclean state. If not, it might be worthwhile running chkdsk.exe over the drive.
After each reboot the external HDD (USB3) does not mount unless I switch off / unplug it.
I have no idea if a reboot produces a "unsafe eject"
The file system of the drive is ext4. Is there a possibility to use fstab?
I have another raspberry 4 running under ubuntu server with two USB harddisks connected. Reboot does not produce any issues there:
How to post a log (wiki)
2. Restart Kodi
3. Replicate the problem
