Coowell V5 Libreelec NAND install failed (SOLVED)
  • Hello kszaq,
    IT WORKS :):):):)
    I finaly have found A image containing 7.1
    I flashed this rom using the usb flashtool
    It flashed complete to 100%
    started the Coowell, but it hangs on the bootscreen.
    I then inserted A SD card containing LE 8.2.
    started LE running installtointernal
    rebooted
    The splash screen was visible and LE started up
    From LE reboot from internal
    to be sure I have removed the cd card and rebooted again.
    The splash screen was visible and LE started up.
    So your workaround from post 11 to install Android 7 was the right one, I only did not remove the DTB.IMG but replaced it with your device tree.
    My mistake I was thinking Android 7 has to complete start up.
    So I went online to let you know it works.
    Then I saw your message containing the Coowell device tree.
    So back i went to my Coowell flashed the coowell Android6 image back
    started up
    then I start LE using your device tree.
    And again everything installed nicely.
    Now I have A running LE 8.2 from NAND no more Android for me:!:
    KSzaq thanks for al your support:):):)
    Edited once, last by Hermankodi (January 4, 2018 at 10:47 AM).
  • Hi @kszaq
    hi @Hermankodi
    I had to replace my 905box because of a hardware defect. I’d like having a S905 again and after searching a while a found a S905 from a Chinese ebay seller. It is labelled with ‘XGODY M8S+’ and it was delivered with Android 5.1.
    I have exactly the problem with this box that is described here. It’s running fine from SD card with device tree ‘gxbb_p200_1G_100M_RealtekWiFi.dtb’ and Libreelec 8.2.3.1. After installtointernal and removing the SD-card I get only a black screen. It’s still running from SD card.
    Unfortunately I can’t use the device tree from this post as it is for S905X and I also didn’t find any newer Android for my box in the WEB.
    Can you my help me?
