need help creating Add-On
  • Hello,
    i trie to implement the wiringPi "https://l.facebook.com/l.php?u=http%3…VABRwMpA4nTpWao"
    to use it with "https://l.facebook.com/l.php?u=https%…ZbaGBum0g3BXCzI" this.
    my Python Script look like this
    I can start the script but nothing happens
    What do I missing?
    This is inside my virtual.wiringPi
    Fernseher:~/.kodi/addons/virtual.wiringPi # ls *
    bin:
    gpio hddledPi netledPi
    include:
    wiringPi.h wiringPiSPI.h wiringShift.h
    wiringPiI2C.h wiringSerial.h
    lib:
    libwiringPi.so libwiringPiDev.so
    resources:
    thank you for help.
  • Is the bin subdir in PATH, and the lib subdir in LD_LIBRARY_PATH? If not, add them.
    Are the files in the bin subdir executable. If not, make them executable.
    Once you have checked this, try to run the commands from the shell, eg, hddledPi -d
    Hope this helps
    i made the files executable and netledPi works
    but on hddledPi I get this error
    Could not find required lines in /proc/vmstatFernseher:~/.kodi/addons/script.hddledPi.kodi #
    found this in the code but I do not know what it means.
