help needed : S912 box and rgb output on old Philips/Sony Tv's
  • hi,
    I tried asking this question in the s912 thread.
    I am running libreelec 8.1.9 version on s912 h96+ box. and I have old Philips TV.
    on versions before 8.0.2.e you could force the rgb output with this command
    #!/bin/sh echo 1 > /sys/class/amhdmitx/amhdmitx0/output_rgb
    however the newer version of libreelec doesn't support this configuration via autostart.sh file.
    if I downgrade to 8.0.2x and execute this command I loose audio via hdmi.
    I have read here something about configuring 8bits/10bits display to force rgb.
    I was wondering if someone here could help me with this issue. I would like to keep up with the updates of libreelec, but I am too beginner to know what and where to configure, so my TV screen does not randomly go green/pinkish when I am in the middle of watching a movie.
    I asked this question in s912 thread too, but only received short replies and no workarounds. hence why I am asking it here.
    please provide me with some guidance how to fix this problem. thank you
  • Can you try running this command: echo cs0 > /sys/class/amhdmitx/amhdmitx0/debug
    nothing happens unfortunately.
    I tried it when the screen was green/pinkish
    and when the output was RGB
    edit: updated to the latest version. still no changes
    Edited once, last by samgarcia (October 8, 2017 at 2:36 AM).
  • Tried it on S905X. Removed all the other settings from autostart, entered the new, rebooted and played a video. Screen turned pink after a few minutes. Nothing in the dmesg after the change to pink.
    FXeF
  • I have the same problem with my Panasonic Plasma.
    However, I have the option RVB colour scale : full / normal.... but the pink/green screen ate still here even when I change the option.
    I'm now on the 8.0.2e version, and everythings works fine.
  • I can confirm the problem with 8.1.9. It exists on two different Monitors from Dell on a Coolme S905X.
    Here the screen is pink/green from the start.
    Thanks to iskonje, this solution also works for me for now.
  • it is not a problem with Libreelec, it is a problem with RGB settings with old Tv/Screens.
    the reason for 8.0.2.X working fine is because @kszag made a special patch around that time.
    but since that version libreelec and built in Kodi have been heavily updated.
    I am willing to participate and help out with the development of a patch to Force RGB output on 8.1.X versions. just let me know how I can help
  • Just wanted to point to the same problem on the same SoC, where the issue was solved by an option in a new firmware:
    incompatible YCbCr and RGB
    The author has the opinion, that there might an incompatibilty between the Box and the monitor/TV, so having the option to switch to RGB is solving in his case.
    I haven't found this possibility in the libreelec, or am I mistaken?
    Closed source Android firmware is not helpful for us. Resolving this issue requires modifying kernel code.
    Switching to RGB 10bit mode should be possible by echo 'rgb,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
  • Switching to RGB 10bit mode should be possible by echo 'rgb,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
    Could I get Full RGB range by similiar command? after this command I have
    Jan 05 10:25:29 CoreELEC kernel: hdmitx: video: Bit depth: 10-bit, Colour range RGB: limited, YCC: limited, Colourspace: RGB
    on Odroid C2. :(
