[RPi] Settings Patch for Interrupted Bluetooth Audio
    I installed the latest LibreELEC using NOOBS on Raspberry Pi 3.
    I turned on the Bluetooth and paired my Bose QuietComfort 35 headphones, and it paired successfully, and then connected.
    Unfortunately, several moments after it connects, it get disconnected and you cannot hear any sound. It happens every time, and I cannot use my headphones at all :(
    Any advice how to solve this issue?
    Thanks.
    Edited once, last by 1gnition (August 13, 2017 at 6:44 PM).
  • Thats the one I use. Bought it in germany.
    Hama Bluetooth-Adapter 4.0 (Nano-Bluetooth-Dongle, inkl. EDR, abwärtskompatibel, USB-Adapter) schwarz ref=cm_sw_r_cp_apa_FLjKzb00R84QZ
    The same is available on amazon.com if you are in the US.
    ref=cm_sw_r_cp_awdb_uPjKzbQW639DV
    Is detected without any problems.
    I am using it rpi 3 no problems, but you habe to disable the inbuilt Bluetooth first.
    You can disable it in the config.txt in the Boot partition.
    AdD the line
    Dt-overlay=pi3-disable-bt
    Edited once, last by Viking (August 13, 2017 at 7:59 PM).
    Thanks for the help. I went and bought this:
    csr8510
    It works completely fine, but for anyone reading this, please be aware of the following:
    1. It will work only in LibreELEC, and it won't work inside Raspbian.
    2. When you pair your headphones, you must make sure you pair them to the bluetooth adapter and not the builtin bluetooth inside Raspberry.
    3. Inside Kodi, after you pair your headphones you must change the audio settings as follows:
      Inside "System settings", choose "Audio", and in "Audio output device" you must choose "PULSE".
    After that, it works perfectly.
  • I encountered very similar Bose Bluetooth behavior on LibreELEC 12.2.1 with a Raspberry Pi 5 and QuietComfort Ultra headphones: successful connections followed by missing/degraded audio, disconnects, and occasional headset reboot loops.
    Testing showed that LibreELEC’s ongoing Bluetooth discovery could interfere with the audio connection. Stopping discovery restored normal audio immediately. I developed a LibreELEC Settings patch that pauses discovery around connected audio devices and adds automatic connection recovery.
    It has been tested with Bose QC Ultra and SteelSeries Bluetooth headphones. This original report is much older and may have had additional causes, but the symptoms are similar:
    GitHub - vincent71711/libreelec-bluetooth-audio-stability: Unofficial LibreELEC Bluetooth audio stability patch for Raspberry Pi 5, tested with Bose QC Ultra and SteelSeries headsets.
    Unofficial LibreELEC Bluetooth audio stability patch for Raspberry Pi 5, tested with Bose QC Ultra and SteelSeries headsets. -…
    github.com
