Test title for TBS 5980 and 5990 Tuners on Arm Devices.
  • I guess this is the wrong section but at least a dmesg | paste would help a lot to see what happens at least
    unplug every DVB device besides the 5990, reboot, try play some channel
    then connect with ssh and enter dmesg | paste and post here the url that is generated.
  • Greetings,
    I opened it here because I did not know where to open the door, so please apologize.
    The link I will make as soon as you say and give it to you.
    But if I can not get the DVB Tuner out of the box, but I can make it passive, would it?
    Best regards...
  • But if I can not get the DVB Tuner out of the box, but I can make it passive, would it?
    I don't have the HW so I can't tell anything :) Thats why the dmesg is needed, could also be a driver bug - no idea actually.
  • Greetings,
    I think this device or chip came with only one tuner support. WeTek programmers wrote on the forum that way.
    So this is the problem?
    Best regards...
  • ozkaradag I though your issue was fixed? Anyway. Looks like USB is unstable. Is your usb device powered? If not please try a powered Usb hub.
    Greetings,
    The USB Tuner is also receiving power. So it has its own electricity.
    Everything is true, but the broadcast is not open because it can not see or receive the signal.
    Best regards...
  • Greetings,
    Yes, I have great news for you.
    TBS 5980 and TBS 5990 USB DVB-S Tuners works superbly in kszaq and GDPR-1 images (ie Mecool K1 Pro and WeTek Play 2 devices). It works really well.
    However, when I plug in the Common Interface (CI) Slot CAM Module, the signal is interrupted, no signal is received, including the FTA.
    If the CI Slot can be run or activated, these tuners and these devices become myths at JEOS and are very popular.
    I believe that the CvH master will solve this too.
    Best regards...
    Edited once, last by ozkaradag ().
  • when I plug in the Common Interface (CI) Slot CAM Module, the signal is interrupted
    dmesg | paste pls, could be a missing/not working submodule, sadly I can't test it in any way so I have to wait for some feedback :)
  • dmesg | paste pls, could be a missing/not working submodule, sadly I can't test it in any way so I have to wait for some feedback :)
    Greetings,
    Many thanks for your interest, dear CvH.
    I will give you the necessary information and assistance, but I can do it in a week.
    Also I can give you a gift as a USB-Tuner, enough that you play CI Slot. :)
    Best regards...
