UPS PIco on LibreELEC [RTC and i2c issue]
  • Dear all,
    I'm struggling to install the UPS PIco HV3.0A "Top end" on the RPI3 running libreelec...
    I tried to follow the instructions provided there:
    UPS PIco HV3.0A Stack Plus on LibreELEC - olausson.de
    but I still can't make the UPS work properly. Here are the points I'm having issue
    So I have the RPi running with libreelec properly, I installed the rpi-tools and system-tools addons
    I plugged the UPS and the battery
    1st issue: nevertheless how to check that
    rtc-ds1307 is available as module
    i2c-dev is compiled into the Kernel
    i2c-bcm2708 is compiled into the Kernel
    2nd issue: RTC is giving issues and hwclock does not respond properly:
    PortableKodi:~ # hwclock -s
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    here is what I added to /flash/config.txt (depending on several website:
    dtparam=i2c_arm=on
    enable_uart=1
    dtoverlay=i2c-rtc,ds1307
    # Since LibreELEC 8 is running Kernel 4.9.8 we need to add the below
    # See <a href="http://www.forum.pimodules.com/viewtopic.php?f=20&amp;t=3442">http://www.forum.pimodules.com/viewtopic.php?f=20&amp;t=3442</a> for an explanation
    dtparam=i2c1_baudrate=10000
    3rd issue: modification of picofssd
    the tutorial recommend to modify the "top picofssd", I have no idea what file I should modify
    then I guess I'm stuck there and need to solve those issue before to continue to install the UPS PIco
    I have also posted this post on the pimodules forum PiForum • View forum - UPS PIco HV3.0A and email the author of the tutorial, but if anyone has some hint on those issue I'll be very gratefull to read it!
    as well not sure in which of the forum category I should post I assume dev is ok...?
    Thanks in advance
    Jeremie
