tvh2kodi addon - configure tvheadend from kodi interface
edit4ever -
July 7, 2017 at 1:19 AM -
belaid38 Thanks - I had typo in the lnb url...try this:
script.module.tvh2kodi-2.0-TEST4.zip
Thanks!
The download link does not work
Access denied. You’re not authorized to view this page.
belaid38 weird - here you go:
thanck you
belaid38 I know it's annoying - but I need the log every time - as it points out my mistakes in the code.
Without it - I don't know what to change as I don't have a DVB-S system to test with.
Thanks!
Please arrange DVB-s, your work help many users
belaid38 If you get a chance - please provide the log from your last LNB access fail attempt.
Thank you.
belaid38 not sure why - but the log file says it is an invalid zip.
belaid38 Thank you - I had a big set of typos on that last one...
Please try this one - and if you get an error - please post the log.
script.module.tvh2kodi-2.0-TEST5.zip
Thanks!
I try to install this script but i don't have anything showing as switch selection under my dvb s tuner in Tvheadend ?
Thanks!
hi edit4ever
open edit satellite lnb/switch is work fine . network AA et AB et BA et BB not open . is error . I want to choose a satellite
Yes i just saw only for universal switch i am looking for switch setup for DVB S non universal lnb
belaid38 OK - for this next part I need to understand how tvheadend accesses the satellite/network list.
Can you try entering the following into a browser and if you get a response, paste those here...
Codehttp://192.168.1.85:9981/api/mpegts/input/network_list?uuid=05bae81424640c0b5eb1f45ace648796 http://192.168.1.85:9981/api/mpegts/input/network_list?uuid=f84f83a10685ca40be586a2e777d6d7b http://192.168.1.85:9981/api/mpegts/network/gridThanks!
mc1 Once I get the universal switch working...if you're willing to test and post errors, I will work with you to get non-universal lnb working.
