Color problem with S905X
zorrua -
June 9, 2017 at 3:12 PM -
the problem is with your TV set. See this thread for a solution:
s905 - hdmi handshake /color space problem with older TVs
Specifically s905 - hdmi handshake /color space problem with older TVs
Thanks! It works!
I add this lines in autostart.sh
Now there is pink or green colors.Best regards.
The latest libreelec versions use a new kernel, and the setting command changed - but as I and others have already reported, it currently does not work.
Thanks mmpp,
Where did you reported?
Kind regards.
You can click on any user icon and see all their posts and likes. We discussed it here: [8.1.2] LibreELEC 8.2 for S905/S905X
8.1.5 has unmodified Amlogic color space handling.
Please first try echo "rgb,8bit" > /sys/class/amhdmitx/amhdmitx0/attr
If this doesn't work try echo "rgb,10bit" > /sys/class/amhdmitx/amhdmitx0/attr
Remember that you have to switch screen resolution after issuing this command. One way to do this is to issue these commands (together): DM=$(cat /sys/class/display/mode) ; echo null > /sys/class/display/mode ; echo $DM > /sys/class/display/mode
