trying to setup tvheadend 4.2 but having some problems. im using the setup wizard and everything is good till i get to the pre-defined muxes. im using a hdhomeurn prime so thats DVB-C network but the only pre-defined muxes its showing me is for countries in europe and im in the US. so all my scan results are failed. if i use the hdhomerun addon i get live tv.
need help setting up tvheadend with hdhomerun prime
chromebox -
May 12, 2017 at 6:28 PM -
I had the same issue, you have to setup a m3u file and it via networks. I the url on how to setup a m3u for prime:
Help! Can't get muxes or channels to detect "properly" - Tvheadend
Then go to networks, add, iptv automatic network,set network name to whatever you want, and then the url of your m3u location.
for example: file:///storage/picon/***.m3u
For the prime you are suppose to set the max number of input streams to 3 since it has three tuners but it didn't work for me. I had to set it to '0' and then it only got the first three channels. Then I set it to '3' and rescanned and got the other channels.
good luck
