Help - Update from 7.03 to 8.01 Kodi not possible
  • Please help me i have an Intel NUC with 128GB SSD.
    I running Libre Elec with Kodi 7.03 works perfect.
    I tried the Update but it cant be installed.
    After reboot the meaasage is not enough memory?
    What to do know?
    This is very sad, hope someone can help me.
    Thank you.
    Greetings
  • Only thing I can think of is that the system partition is too small, and not the internal memory. But that should have happened with 7.0.3 already as well.
    Standard solution: make a full backup with the internal Backup/Restore tool, and keep the backup file in an external location. Then install 8.0.1 fresh, so new partitions are created, and after that, restore the backup into the 8.0.1 build.
