Hello.
libreelec 8 kernel has built in netconsole feature (netconsole.txt)
which is useful for debugging kernel related problems.
Unfortunately it's built in into kernel and not as module. When it's built in into kernel the only way to activate it is to pass
parameters via /flash/cmdline.txt like:
That won't work because eth0 is initialized later, after netconsole thus kernel will say:
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 netconsole=@/,@192.168.0.249/ quiet root=/dev/ram0 rdinit=/init BOOT_IMAGE=/kernel.img usbcore.autosuspend=-1
[ 0.964904] netpoll: netconsole: local port 6665
[ 0.964909] netpoll: netconsole: local IPv4 address 0.0.0.0
[ 0.964911] netpoll: netconsole: interface 'eth0'
[ 0.964913] netpoll: netconsole: remote port 6666
[ 0.964915] netpoll: netconsole: remote IPv4 address 192.168.0.249
[ 0.964921] netpoll: netconsole: remote ethernet address ff:ff:ff:ff:ff:ff
[ 0.964925] netpoll: netconsole: eth0 doesn't exist, aborting
[ 0.965019] netconsole: cleaning up
Solutions:
1) make netconsole as module instead of built-in, so it can be modprobbed like
OR
2) enable dynamic netconsole configuration capability CONFIG_NETCONSOLE_DYNAMIC
LibreELEC:~ # modprobe configs
LibreELEC:~ # zcat /proc/config.gz |grep NETCONS | grep DYNA
# CONFIG_NETCONSOLE_DYNAMIC is not set
I hope one or both solutions can be applied to libreelec kernel.
Thanks!
