Problem ethernet conneciont Beelink Mini MX III
  • Hello I have a Beelink Mini MX III and I can not get the ethernet connection LibreElec 8. On the router itself does not turn on the light of the connected ethernet port. I restarted several times and nothing. Other times, after a few reboots, I get it to detect it, but this time there is no way. What I can do?
    Thank you
    Thank you
    Whilst the box is on pull the ethernet cable out and plug back in until you see it detected by router.
    It may take a few in and out with cable.
    When detected you have to reboot box.
    It only happens when power is un plugged from box.
    I am on [7.0.3.012j] and it never happens anymore.
    It used to happen on previous early versions.
    Maybe the ethernet module loading problem for this box has re surfaced.
