Hello,
It is possible to get 2 audio output at the same time?
I search this proyect: GitHub - xhbl/OpenELEC_dualaudio: OpenELEC Dual Audio Project Repository
It is possible to integrate inside Libreelec?
Kind regards.
Hello,
Kind regards.
There you go....anyway it would be a nice feature if it could be in the official releases
Thanks!
Yes, it will be great to get official builds for that.
Is it possible to configure asound file to configure alsa?
Best regards.
don't expect official dual-audio builds unless Kodi adopt the feature/capability upstream
Thanks for the reply.
So this feature must apply in Kodi?
I remember some years ago I installed XBMC in Debian and I could configure ALSA with 3 different audio devices (HDMI, optical and analog) and then select it in XBMC configuration menu.
Could we (Libreelec) configure a new audio device with ALSA or PulseAudio and then select it in audio menu?
Best regards.
