Any news Milhouse?
Fresh install on Pi2 and unable to install add-ons
McRam -
June 13, 2016 at 3:35 PM -
No, to be honest I don't see any errors/issues in either dmesg so I can't explain why the fsresize is failing when using the sdhost driver. I wonder if a dmesg from a freshly imaged SD card would reveal the issue, but this would require you to re-image your SD card, allow fsresize to fail, then grab the dmesg - I'd expect there to be some mmc-related errors logged.
No, to be honest I don't see any errors/issues in either dmesg so I can't explain why the fsresize is failing when using the sdhost driver. I wonder if a dmesg from a freshly imaged SD card would reveal the issue, but this would require you to re-image your SD card, allow fsresize to fail, then grab the dmesg - I'd expect there to be some mmc-related errors logged.Hello Milhouse,
The second dmesg I posted is from a "failed" install. So if you do not see any issues with that one I guess we are stuck. At least it now works for me so should anybody else have the same issue they can find the solution in this thread. Thanks again for your help. This thread can be closed.
