Hello dear community, I'm quiet new to the RPI and LibreElec/Kodi, however, I have a problem with the latest release, running it on my 'naked' PI 3.
When I power on the PI, in the past three months (until release 7.95.1) , the following happened:
- red led went on
- green led was flashing
- Display went on, displaying the "startup-screens" (LibreElec-Version and Krypton-Logo)
- Kodi was ready -> red led was constantly on, green led was flashing frequently
After the update on 7.95.2 the following happens:
- red led goes on
- green led flashes exactly once
- display is showing a multi-coloured-square for a few seconds
- then booting starts as used , displaying the "startup-screens" (LibreElec-Version and Krypton-Logo)
- Kodi is ready
however the green activity LED is completely off and only turns on (flashing some times) when I shutdown the system.
Kodi seems to be working as usual.
I removed all USB-Devices, the LAN cable > same symptoms
I did reset the system to default values > same symptoms
I did not turn on the debug log, but there was nothing than the successful start event in the regular event log.
I did make a backup and then formatted the sd-card writing the image of 7.95.1 > now the PI works as usual
I did make a new image with 7.95.2 > the symptoms (no green-led activity and displaying the colored square) start to show up from the first start (before the setup routine starts)
What's wrong with this version and how may I contribute to fix the problem?
