I guess you enabled the setting?
LibreELEC Krypton/Leia/Agile build for Odroid C2, Rock64, WeTek Hub, WeTek Play2
GDPR-1 -
January 27, 2017 at 8:28 AM -
Closed -
which setting do you mean
yes i enabled Start stop and always. No chance . at first start up it wont switch to correct frame rate.
Release rb-leia12 · Raybuntu/LibreELEC.tv · GitHub
tunay You mean you need to reboot to make it work? I'd try to update wetek android firmware just in case.
android firmware is updated. any orther ideas? issue still there
What version are you using? Please provide debug logs.
i tryed both jarvis and krypton. same Problem raybuntu. i need to restart the device to get correct frame rate.
I do not provide jarvis builds. Are you sure you are using my builds?
i think it is a major problem on all wetek hubs.
I'm sorry for you but I can't reproduce it on my Wetek Hub using my build. This Topic is mainly about my community builds.
Recently I've contributed with an update to lcdproc together with another user to support a different type of OLED display and a VFD display.
I saw that it's not yet in the new builds.
The build toolchain Isn't supposed to get the latest sources from the github from this repo ?
GitHub - lcdproc/lcdproc: Client/server suite for controlling a wide variety of LCD devices
The last package bump was in March 2017: History for packages/addons/service/lcdd/package.mk - LibreELEC/LibreELEC.tv · GitHub
You can contribute a package bump. There is nothing happening automatically here. Package is still at git 466edd3
I'm not very familiar with git. I just use it the dumb way:
pull, push, merge, rebase, commit
So what's a package bump and how should I create it ?
LibreELEC.tv/package.mk at master · LibreELEC/LibreELEC.tv · GitHub
These are the values you need to adjust, then build lcdd/LibreELEC from scratch. If it fails you need to check what changed or fix some compile issues with a patch. Test your changes. If they work you can open a PR on github.
Thanks.
Release rb-leia14 · Raybuntu/LibreELEC.tv · GitHub
Hyperion Addon might not work with this version cause of recent changes in Kodi master
Make sure you update your addons too.
Hi guys,
After a bit of troubleshooting for my Wetek Hub Bluetooth.
I installed to NAND using the latest build from here - WeTek Hub – LibreELEC
I then SHH's in did a
followed by a
Codewget https://github.com/Raybuntu/LibreELEC.tv/releases/download/rb-leia14/LibreELEC-WeTek_Hub.arm-9.0-rb-leia14.tar
After reboot - I turned on Bluetooth in the LibreElec settings but when I go to the Bluetooth settings I get a No adapter present message.
lsmod over ssh outputs
Display MoreLibreELEC:~ # lsmod Module Size Used by 8021q 17367 0 btsdio 2962 0 bluetooth 238085 6 btsdio 6lowpan_iphc 5871 1 bluetooth ir_lirc_codec 4025 0 lirc_dev 6771 1 ir_lirc_codec meson_ir 3657 0 rc_core 21779 4 lirc_dev,meson_ir,ir_lirc_codec mali 183319 5 dhd 694992 0 cfg80211 230552 1 dhd amlvideodri 10458 0 videobuf_res 5082 1 amlvideodri videobuf_core 16059 2 amlvideodri,videobuf_res videodev 131290 1 amlvideodri LibreELEC:~ # service bluetooth status -sh: service: not found
any thoughts?
