Hi there, using kszaqs latest build on s905x box. Connected my box to TV via hdmi and active speakers to analog out jack. Both outputs have audio, but...
There's a delay, possibly caused by TV's picture processing resulting in delayed audio over hdmi in contrast to analog out.
I like to setup for having both outputs working without delay while TV is on and analog always on, for to have audio still when TV is off.
So I've got a few issues here...
1.) I can't understand how it is handled, that analog and hdmi are on at the same time, hardware related or using alsa?
2.) is there a way with alsa or pulseaudio, to set a delay on analog out?
I've got 3 sinks in kodi. Hdmi, pcm (both alsa) and bluetooth (pulseaudio). There no difference between switching the first two
Read, that pulseaudio should be able to delay an audio sink, but therefore it needs pulseaudio enabled (see 2.) and I don't know what's best way to go...
Another option would be to suspend the output videowise. If I connect the speakers to TV's analog output, audio is in sync, but switching off TV switches off audio, too ![]()
Any tipps welcome! Thx in advance
P. S. I know this thread: LibreELEC
