I have this (ASUS B150I Pro Gaming/WiFi/Aura) motherboard but wifi is not working. Settings/LibreELEC/Connections is empty.
Does anyone know how to fix this?
I assume it will be the same issue I have with a box, there is no WiFi driver and to fix you would have to compile an image with the included driver. How you do this, well I've not figured that part out
Sent from my S600 using Tapatalk
The motherboard has Intel chipset B150 and I think wifi is "Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter".
I think LibreELEC has these drivers, there is directory "/lib/firmware/ath10k/QCA6174"
I also tried mythbuntu and wifi worked just fine and that is much older distro. LibreELEC (beta) should have kernel 4.8 and Intel B150 chipset was supported since 4.3..
Anyone?
