Need help with Xbox One Media Remote
  • On a test box with the new Kodi 13. the Xbox One Medial Remote does not work the same.
    The 2 buttons that are not working are the Top Middle X button that used to take me back to the home screen.
    and the top right context menu button that would open the context menu . It now says the PVR addon is not installed or configured. I dont use a RVR
    Can anyone advise what i need to change in the remote.xml.
    Not to worry. I eventually figured it out.
    For Xbox One Media Remote. in location /storage/.kodi/userdata/keymaps/keyboard.xml
    I had to put the following inside keyboard.xml. all the other buttons work fine.
    <?xml version="1.0" encoding="UTF-8"?>
    <keymap>
    <global>
    <keyboard>
    <epg>ContextMenu</epg>
    <launch_media_center>ActivateWindow(Home)</launch_media_center>
    </keyboard>
    </global>
    </keymap>
    Edited once, last by k_zeon: Merged a post created by k_zeon into this post. (November 28, 2026 at 11:09 PM).
