Agree... btw, per our chat, I'm not seeing banding w/TNM w/the 'Superman' 60fps 3D sample. Looks like it's being rendered at 12bit? Maybe 10bit converted to 12? Better insights for sure w/LumenOS installed. But, 3D doesn't automatically engage as someone at AVSForum showed in his video. Will ask him what he did to make it work.
[x86-64][hadesdevls Builds] LibreELEC Hades - native Dolby Vision, HDR10+ and 3D
hadesdevls -
March 14, 2026 at 2:33 PM -
Thread is Resolved
ht2tweak thanks for pinning it down! Getting wrong colours in 3D with anything but "As SDR" is a bug on my side, and the fix comes in the next update. On the 60 fps side by side file: in your earlier log Hades did switch a file like that to 3D, half side by side at 1080p 60 Hz, with the 3D signalled over HDMI, so on my end it went out as 3D. You'll know better than me whether the receiver could be dropping that on its way to the projector.
Ryudoadema thanks for the log. The projector lists no 48 Hz mode (23.976 to 30, 50, 59.94 and 60 Hz), so there was nothing to switch to and it stayed at 60. The right eye flickering after going back to the menus should be fixed in 1.2.3, and with "As SDR" for 3D Dolby Vision films, as ht2tweak found, 1.2.3 should work well for you too.
Don't know. Maybe I need to get a HDMI splitter to split audio audio to AVR and video from all my Kodi boxes to projector bypassing AVR.
For the 5 GHz Wi-Fi, try setting your country in Settings > LibreELEC > Network > Wireless Regulatory Domain; without it some cards don't show 5 GHz networks.
The failed update from 1.2.2 matters most to me. Could you open an issue on GitHub and attach the logs there? Thanks!
Setting the domain was the solution for the 5GHz
Well I already updated using the installer in Windows. Any way to still get the logs?
I remember it said the download failed of something about signature, the error came fast only a second or so after pressing update. -
