We add soon (this weekend) a new version that includes the change to labwc (like at this test addon) and adding a screensaver to avoid burn in. The keyboard stuff is getting later added.
HDR is currently out of scope, but we look into it for future updates.
That's great, I've still been testing and hacking the test add-on you built last week. Can you consider adding this wlroots patch? https://github.com/CroqueMr/libre…c-on-exit.patch it fixes the problem I raised here [x86-64] After Flatpak add-on execution Kodi no longer outputs 10 bit when required
Labwc is pretty cool, with a bit of tweaking I've got freesync working in Moonlight and HDR too, but you need a libreelec build with Vulkan enabled (i've been using the YBLOD build), rebuild wlroots with Vulkan support and some Labwc configuration. So makes sense to leave HDR for now.
