Flatpak / External Helper - Pointer hits virtual wall / Cage compositor pointer constraints not implemented (yet)
  • We add soon (this weekend) a new version that includes the change to labwc (like at this test addon) and adding a screensaver to avoid burn in. The keyboard stuff is getting later added.
    HDR is currently out of scope, but we look into it for future updates.
    That's great, I've still been testing and hacking the test add-on you built last week. Can you consider adding this wlroots patch? https://github.com/CroqueMr/libre…c-on-exit.patch it fixes the problem I raised here [x86-64] After Flatpak add-on execution Kodi no longer outputs 10 bit when required
    Labwc is pretty cool, with a bit of tweaking I've got freesync working in Moonlight and HDR too, but you need a libreelec build with Vulkan enabled (i've been using the YBLOD build), rebuild wlroots with Vulkan support and some Labwc configuration. So makes sense to leave HDR for now.
  • Quick heads up: updated externalhelper and flatpak addons are now in the repo.
    externalhelper now uses the labwc compositor instead of cage, you can enable screen blanking in the externalhelper addon settings and volume control with multimedia keys should work, too (no visual feedback though).
    This is great, everything is working here: pointer restraints, screen saver/blanking, custom resolutions including VRR, multi channel audio.
