[LE13 Amlogic] problem with ir-keytable: -c -w works, but -a reports an 'invalid parameter"
  • my file /storage/.config/rc_keymaps/ru880_vcr-code131.toml:
    ir-keytable -c -w /storage/.config/rc_keymaps/ru880_vcr-code131.toml works:
    Read ru880_vcr-code131 table
    Old keytable cleared
    Wrote 30 keycode(s) to driver
    Protocols changed to nec
    This is the ouput of ir-keytable:
    I am not sure if Default keymap: rc-odroid is right or if there should be reported the just configured custom toml. Anyway, the remote works (tested with evtest using meson-ir on /dev/input/event3)
    Event: time 1793725093.577050, type 1 (EV_KEY), code 28 (KEY_ENTER), value 1
    Event: time 1793725093.577050, -------------- SYN_REPORT ------------
    Event: time 1793725093.858062, type 1 (EV_KEY), code 28 (KEY_ENTER), value 2
    Event: time 1793725093.858062, -------------- SYN_REPORT ------------
    Event: time 1793725093.866751, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
    But after starting eventlircd and kodi nothing happens in kodi when I press any key. There is nothing in the kodi debug log.
    When I try to make the keymap permanently with ir-keytable -a /storage/.config/rc_keymaps/ru880_vcr-code131.toml -s rc0 I get an error:
    Invalid parameter on line 1 of /storage/.config/rc_keymaps/ru880_vcr-code131.toml
    ir-keytable: Failed to read config file /storage/.config/rc_keymaps/ru880_vcr-code131.toml
    I don't see anything wrong in my toml and if so, I assume that this would have been reported by ir-keytable earlier when using -c -w  instead of -a.
  • According to this: https://wiki.libreelec.tv/configuration/…iguration-basic the "-a" switch is to load the rc_maps.cfg not to load the toml file. So you should make a copy of /etc/rc_maps.cfg or create a empty one, add a line with a reference to your toml file and load afterwards the /storage/.config/rc_maps.cfg via ir-keytable -a /storage/.config/rc_maps.cfg.
    The line in the file `/storage/.config/rc_maps.cfg` might look something like this configuration
    meson-ir * ru880_vcr-code131.toml
    or
    em28xx * ru880_vcr-code131.toml
    depending on which IR receiver you wish to associate the configuration with.
    Edited 2 times, last by HarryH: Configuration examples added (November 3, 2026 at 6:09 PM).
  • thank you, I looked for hours on the screen but did not see it :cry:
    Do you have an idea why Kodi does not react to the remote? I have already vdr (from https://github.com/Zabrimus/VDRSternELEC) running (while kodi is stopped). The vdr OSD reacts now fine to remote key presses. Kodi should be able to react to /dev/input devices with or without eventlircd, but no success. Even the Kodi debug log shows no remote key presses. Keyboard works fine.
  • Do you have prepared the required rc_maps.cfg file now? I'm not familiar with the Amlogic devices and their culprits. Is it a recent LE13 version that do you have installed? Do you have already seen this: Important change in LE13 remote handling ?
    Keyboard events were different handled than remote keys. Do you have some customization in place from the past?
  • yes, the rc_maps.cfg is fine now and the keytable is set permanently. I use the lastet nightly amlogic LE13 for Odroid N2.
    I saw the thread you mentioned but found no explaination. At a second look I think #5 could be important.
    Quote
    You had to map linux input codes (like KEY_MENU) to those kodi remote button codes via a Lircmap.xml and then map the kodi remote buttons to kodi actions in remote.xml.
    I will have a closer look into this... sounds very difficult. I already tested CoreELEC CE22-no. It is also bleeding edge, but there is no problem with linux input event codes.
