ASRock J3455-ITX problem with HBR audio passthrough
  • System
    • Board: ASRock J3455-ITX (Intel Celeron J3455, Apollo Lake)
    • LibreELEC: 12.2.1 (Generic.x86_64), Kodi 21.3 "Omega"
    • Receiver: Onkyo TX-NR709
    • Same HDMI cables and same receiver I was using ~5 years ago on an older LibreELEC build (roughly the 9.2/10.0 era), where TrueHD/DTS-HD MA passthrough worked — intermittently, but it worked. (Had to start the Receiver first and then boot the Kodi player machine - this is why I say intermittently)
    Symptom
    On current 12.2.1, Dolby TrueHD and DTS-HD MA passthrough produce no audio at all. Regular Dolby Digital (AC3) and DTS core passthrough work perfectly every time. Video and everything else plays back fine.
    What I've ruled out
    • Not a Kodi settings issue — passthrough is enabled correctly for both TrueHD and DTS-HD, and kodi.log shows clean negotiation every time:
      CAEStreamParser::SyncTrueHD - TrueHD stream detected (8 channels, 48000Hz)
      Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, pass-through)
      CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x09"
    (AES3=0x09 = non-audio/compressed bitstream flag correctly set.) Same clean result for DTS-HD MA via SyncDTS. Zero ALSA errors, no underruns, no sink failures, in every test.
    • Not the EDID/ELD/proc/asound/card0/eld#2.0 shows a fully valid, complete capability read from the Onkyo, including both HBR formats:
      sad6_coding_type   [0xb] DTS-HD
      sad6_rates         [0x1ec0] 44100 48000 88200 96000 176400 192000
      sad7_coding_type   [0xc] MLP (Dolby TrueHD)
      sad7_rates         [0x1480] 48000 96000 192000
    Read at the exact same time as a failed playback attempt — so the driver has correct capability data and Kodi is using it correctly; the failure is downstream of both.
    • Not the cable — swapped to a different HDMI cable connected to a different (aux) HDMI input on the receiver. Identical failure.
    • Not video bandwidth contention — dropped resolution/refresh rate to the minimum possible. Identical failure. (Rules out the onboard DP→HDMI converter simply running out of bandwidth when video + HBR audio compete.)
    • Not the receiver or general HDMI wiring — this exact receiver, on this exact cabling, passed TrueHD/DTS-HD MA (at least intermittently) on an older LibreELEC release a few years back. Since the AVR and cables haven't changed, that points at something that changed on the software/OS side between then and now.
    My question
    Has anyone else seen a regression like this on Apollo Lake (J3455/J4105-class) boards — HBR passthrough (TrueHD/DTS-HD MA) breaking while standard passthrough (AC3/DTS) keeps working — between older LibreELEC/Kodi builds and current 12.2.1/Kodi 21.3? I'm about to test an older LibreELEC image from a spare USB stick to confirm whether it's a kernel/i915 HDA-audio-component regression, but wanted to check if this is already a known issue before I go digging further.
    Logs
    Without debug
    paste.libreelec.tv/unmined-gertude.log
    With audio debug
    paste.libreelec.tv/autopsic-bernadette.log
  • Even if someone identifies an issue on LE12.2 we aren't going to ship another release so the first/only thing to test next is a current LE13 nightly. Also, if this is a device with an onboard LSPCON chip in the HDMI chain ensure all the firmwares are updated.
