Got it.
Same results I think.
https://paste.libreelec.tv/triacid-leola.log
shows connected with new ip but no traffic
This is as far as I got a few months ago.
Got it.
Don't know if this will help but on the Libreelec info under Connections it shows an ip address different from the ip shown in wireguard app
Just for fun I tried a different locale and VIOLA. PIA -US West streaming optimized connected with normal traffic. I tried another silicone valley and no traffic. Very odd.
That is a known issue with PIA. Dynamic, load-balanced auto-regions frequently establish a local connection link but fail to route internet traffic due to two infrastructure conflicts:
But for the rest you can connect?
Salute.
As I mentioned US West location seemed to connect with good speed. I then added Silicone Valley Location and no connection. I tried to modify the list and WG manager froze then said No provider list. Humm.
I uninstalled WGM and started fresh. Once again to US West location and get errors I think it said missing valid link?
Good info to know. I would change to Nord but have a three year commitment to PIA as price is great and I've had no issues other than LE updates to latest security. Been using PIA for years on all my devices and never experienced any problems so WG seems a logical solution to keep LE alive on my PIs. Hope you can iron out some of these issues and anything you need I'm willing to test.
Try this service.wireguard.manager-1.4.6~beta.2 it fixes a critical crash caused by a base64 regex false-positive on raw alphanumeric passwords during PIA authentication tunnels.
v1.4.6~Beta.3 (2026-05-31)
- Fixed a potential NameError by consolidating global imports and resolved an issue parsing multi-line JSON payload formats in the core network utility module.
Uninstalled beta-2 rebooted installed beta-3
previous location selections were still there.
https://paste.libreelec.tv/postorbital-melina.log
"could not fetch server list for PIA"
v1.4.6~Beta.4 (2026-05-31)
- Implemented a multi-line JSON stream parser in the network utility module to correctly extract endpoint objects from complex server data payloads without crashing.
https://paste.libreelec.tv/nephrotoxic-derrick.log
I tested 3 locations and only one had traffic US West optimized. Might be useful to auto update/Regenerate locations after a change.
First do:
To get rid of "2026-05-30 23:50:13.420 T:1372 error <general>: service.wireguard.manager v1.4.6~beta.4: Password decoding failed, using raw password: 'utf-8' codec can't decode byte 0xe0 in position 2: invalid continuation byte"
On every connection, the add-on gets all data live from PIA API to request local server WireGuard configurations before handing control over to ConnMan. This auto-update/Regenerate locations on every new connection. What does
say about the connection?
- We are not fans of discussion on VPN services used to hide piracy or bypass geolocking
- User accounts posting VPN service recommendations will be deleted without warning
Doemela I have removed one of your posts as it contained direct links to VPN services providers and read like an advertorial post endorsing a service. There is no problem to support your addon here as long as threads/posts focus on technical issues and remain aligned with forum rules, thank you.
