[x86-64] USB device not accepting address problem
  • Hello, I have this message every time I boot my mini PC MSI CUBI N JSL-001BEU x64 after libreelec 12.0 update, also when I use suspend fucntion usb ports are not working. Any ideas?
    [ 29.071245] usb 1-8: reset full-speed USB device number 3 using xhci_hcd
    [ 44.440549] usb 1-8: device descriptor read/64, error -110
    [ 60.022974] usb 1-8: device descriptor read/64, error -110
    [ 60.243095] usb 1-8: reset full-speed USB device number 3 using xhci_hcd
    [ 75.818303] usb 1-8: device descriptor read/64, error -110
    [ 91.399666] usb 1-8: device descriptor read/64, error -110
    [ 91.619776] usb 1-8: reset full-speed USB device number 3 using xhci_hcd
    [ 96.832354] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
    [ 97.035860] usb 1-8: Device not responding to setup address.
    [ 97.239201] usb 1-8: device not accepting address 3, error -71
    [ 97.239238] usb 1-8: WARN: invalid context state for evaluate context command.
    [ 97.355927] usb 1-8: reset full-speed USB device number 3 using xhci_hcd
    [ 102.381709] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
    [ 107.717581] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
    [ 107.920983] usb 1-8: device not accepting address 3, error -62
    [ 107.921037] usb 1-8: USB disconnect, device number 3
    [ 108.037709] usb 1-8: new full-speed USB device number 4 using xhci_hcd
    [ 123.414717] usb 1-8: device descriptor read/64, error -110
    [ 138.994715] usb 1-8: device descriptor read/64, error -110
    [ 139.214789] usb 1-8: new full-speed USB device number 5 using xhci_hcd
    [ 154.787737] usb 1-8: device descriptor read/64, error -110
    [ 170.366966] usb 1-8: device descriptor read/64, error -110
    [ 170.470373] usb usb1-port8: attempt power cycle
    [ 170.857131] usb 1-8: new full-speed USB device number 6 using xhci_hcd
    [ 176.012355] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
    [ 176.215829] usb 1-8: Device not responding to setup address.
    [ 176.419147] usb 1-8: device not accepting address 6, error -71
    [ 176.419187] usb 1-8: WARN: invalid context state for evaluate context command.
    [ 176.535855] usb 1-8: new full-speed USB device number 7 using xhci_hcd
    [ 181.561005] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
    [ 181.764463] usb 1-8: Device not responding to setup address.
    [ 181.967780] usb 1-8: device not accepting address 7, error -71
    [ 181.967819] usb 1-8: WARN: invalid context state for evaluate context command.
    [ 181.967861] usb usb1-port8: unable to enumerate USB device
    Greetings
  • The device descriptor read/64, error -110 means a conn3ction establishment error, sometimes that a that USB port power supply was exceeded. Can you please disconnect all USB devices and reboot, and then add them back one by one to identify the failing device.
    I can see the keyboard as 1-7.
    Also please share the lsusb from the system.
