[RPi4] Problems with DVB-T2 Channels
  • Full hardware specs (GPU is most important)
    Raspberry Pi 4 B, 4 GB of RAM, Terratec Cinergy T2 Stick HD
    The LibreELEC version you are running ('latest' is not a version number)
    RPi4.aarch64-nightly-20250419-680d127
    In most cases a full debuglog
    https://paste.libreelec.tv/cool-parakeet.log
    Tell us the complete steps how to face the issue, so we can try to reproduce
    I have only installed the addons service.tvheadend43 and pvr.hts to be used with a Terratec Cinergy T2 Stick HD DVB-T/T2/C USB receiver. After having configured the addons the DVB-T channels in Finland can be viewed as expected without any problems.
    The problem occurs with the DVB-T2 channels. Opening them takes a long time or fails alltogether if opening and closing the channels several times. The Kodi GUI becomes also unresposive sooner or later.
    When closing DVB-T2 treams with the square symbol in the Kodi GUI I can see from the Tvheadend webinterface that the stream continues to run after I have tried to close it. The Tvheadend webinterface also reports some errors when DVB-T2 channels are opened.
    I have seen this problem also on
    LibreELEC-RPi4.arm-10.0.4
    LibreELEC-RPi4.arm-11.0.6
    LibreELEC-RPi4.aarch64-12.0.2
    but version LibreELEC-RPi4.arm-9.2.8 works as expected.
    Additionally to the above, if you are facing video playback issues:
    A full debuglog while trying to play the video
    Informations about the Kodi video and audio settings (maybe a
    screenshots from both)
    These settings are unchanged from the default settings,
    Best regards, RPi4_user
  • The HD-channels in Finland I try to watch are freely viewable, so I don't have any CAM module installed.
    I tried looking for a DRM Prime setting, but I could not find it. What is the menu path to that setting?
