I'm launching
			ir-keytable -p lirc -p rc-5 -p rc-5-sz -p jvc -p sony -p nec -p sanyo -p mce_kbd -p rc-6 -p sharp -p xmp -p imon -p rc-mm
	nothing happens. All other remotes show scanning. But not Iffalcon.
Then I decided to test lirc. I installed bookworm and lirc, ran irrecord, and the file was created.
iffalcon.lircd.conf
				begin remote
  name  IFFALCON_TV
  bits           24
  flags SPACE_ENC|CONST_LENGTH
  eps            30
  aeps          100
  header       3968  3996
  one           489  1999
  zero          489  1007
  ptrail        489
  gap          65238
  min_repeat      7
#  suppress_repeat 7
#  uncomment to suppress unwanted repeats
  toggle_bit_mask 0xA30A3
  frequency    38000
      begin codes
          KEY_UP                   0xF590A6
          KEY_DOWN                 0xF580A7
          KEY_LEFT                 0xF560A9
          KEY_RIGHT                0xF570A8
          KEY_OK                   0xFF400B
          KEY_EXIT                 0xF060F9
      end codes
end remote
			Display More
	This is an Android TV, so CEC does not work very well.
Can you help, is it possible to solve the problem?
Is it possible to control libreelec with this remote?
