Volume Control with Hifiberry Amp4pro
  • Hi all,
    I‘m running LE12.0.1 on a raspi 5 connected to and powered by a hifiberry Amp4pro. Everything is fine so far, except volume control by mce remote is not working.
    As remote I‘m using an old Harmony Hub which is connected via bluetooth to Libreelec. All commands work perfectly except volume control. Key presses reach the system, for the screen brightens up, when I hit Volume up or down. Even Mute and Unmute work perfectly, only simple volume button presses don‘t seem to send the correct commands. Using the kodi remote app on my cellular works, too. Any idea what I‘m missing? This used to work on a pi4 and amp2…
    In my config.txt I have added
    force_eeprom_read=0
    dtparam=audio=off
    dtoverlay=hifiberry-amp4pro
    Thanks for any ideas
    Tomatensalat
