like i said in the title im facing problems with overlays. im using a tv box with allwinner h3 running opi pc plus image installed to the emmc. the overlay im trying to use is sun8i-h3-spdif.dtbo. i also intend to use the sun8i-h3-tve.dtbo overlay for cvbs out. what happens is when try to boot it shows the initialising procces and just straight up hangs by the line /run init. tried rebooting didnt help. so what i did was use an sd card booted with le and change the extlinux.conf file with stock one. any help is appreciated
H3 onboard spdif (enabled with overlay) no audio out
Gallahad  -
June 18, 2024 at 2:15 PM  -
Share the contents of the modified extlinux.conf file.
it looks like i cant attach the file . so here's the contents that i copied
LABEL LibreELEC
LINUX /KERNEL
FDT /sun8i-h3-orangepi-pc-plus.dtb
FDTOVERLAY /overlays/sun8i-h3-spdif.dtbo
APPEND boot=UUID=2601-4656 disk=UUID=c8d7999e-09ae-49aa-bf85-76c35602095c quiet console=ttyS0,115200 console=tty1 -
FYI, i have also tried to do the same with the build on the sd card that i had previously used for recovery purposes. and i got the same output
update, i found the problem i used FDTOVERLAY instead of FDTOVERLAYS, spdif out does show up but theres no audio through the spdif optical port
Please run "amixer contents | paste" and share the URL - I suspect one of the controls needs switching.
i used the same with an allwinner android image and it works fine so can i like copy paste things from that image
