Power on Issue -LibreELEC-WeTek_Hub.aarch64-7.90.009
  • Wetek HUB NAND Install
    After shutdown with the remote the Hub didn't start by remote. Only disconnecting the powersupply starts the Hub.
    Edited once, last by meikel (December 7, 2016 at 9:42 AM).
  • This is expected and documented in the v7.90.009 release notes:
    "WETEK HUB REMOTE
    The popular WeTek Hub box ships with a small and simple remote and many users would like a larger remote with more feature buttons. To accommodate this we are testing a switch from amremote to lirc which allows the on-board IR sensor to be configured for other remotes. These changes remove the Airmouse function which has little use under Linux, and the ability to power-on the device from the remote. We consider power-on important and are investigating changes to restore that capability."
    Edited once, last by chewitt (December 7, 2016 at 11:17 AM).
