This is driving me crazy but when I put my Asrock 330 in standby mode the power led keeps blinking constantly.
Using the latest LE 7.0.0
Blinking LED in suspend is a motherboard specific feature. Nothing you can do in software to disable it.
Try your motherboard BIOS settings, or alternatively disconnect the power LED from the motherboard header.
You sir are absolutly right
Forgot i had that option in the bios.
And for others with the same problem.
Some versions of Asrock ION 330/pro/HT/BD have this in a newer bios version. It's called Good Night Led
