LibreElec Rpi4 TVHat TVHeadend - Recording Problems
  • I was not totally sure of the precedence of collector that should be set to keep the latest epg and if one will totally overwrite the information collected by another or just update it? If you understand what I mean? So if I have collected the 7 day epg with Freesat, then a later run collects it with Open Sky, does that Sky collection totally overwrite the Freesat collection or just fill in the gaps? I only have the Sky one enabled as well as the Freesat as I find info from some channels will be missing without it.
    I've wondered about this as sometimes I get series/episode info in the TVH gui then at a later point I don't so I have suspected if one collector has this info it could be being overwritten by the one that doesn't.
    Then the now/next info/EIT - should this be set at highest precedent or lowest? As I mention before I have set 2 different tuners with an alternate order of precedence. But both tuners still hold a full 7 day epg, although the one dockered on my server is not that often used for playback, more for recordings. So I can't really tell the difference being made by the order.
    I would only run Sky or Freesat EPG collectors - not both - or if you do have both - chose one EPG source per channel.
  • All channels on Freesat devices have OpenSky listed as epg source - none of them mention freesat as source, even though this is the predominant mux I schedule (11425H). I will experiment by removing the sky collector on my docker - but suspect I will have missing data for some channels.
    On Freeview Pi box there is no item listed in the channels epg source.
    I just use the Open TV Sky UK EPG collector on my current main recording instance - which is using 4 tuners of an 8 tuner SAT>IP server, and that instance also has Freeview enabled for a Silicon Dust Quad DVB-T/T2 tuner. I have used the Freesat EPG source in the past - but my current set-up has been using Sky EPG data since I started from scratch. On a previous install I had some issues with missing EPG data from the Freesat EPG after a while, which is why I re-started from scratch with a new install running with the Sky EPG (This main TV Headend recording server is running on a Debian OS with OpenMediaVault on an cheap Celeron x86 box with an 8TB USB 3 hard drive connected. However I also have a pair of Pi 4s running Raspberry Pi OS that are able to use other tuners on the same DVB-T/T2 and S/S2 network tuners - and both are running fine).
    I use the BSkyB Bouquet 5 - HD England : London to allocate logical/local channel numbers from the Sky EPG.
    I only have the PSB3 mux in my set-up for Freeview (I sometimes want to record both Freeview HD and Freesat HD variants of the same broadcast) currently - and the EPG source entries for that, like yours, are blank.
    I've manually renumbered the Freeview HD channel numbers to the 1xxx range and renamed them to have DVB-T2 in their titles so I can explicitly schedule DVB-T2 recordings.
    I have no obviously missing EPG data - though I used to suffer from missing channel listings data occasionally (usually when they had changed transponder)
    Edited 2 times, last by noggin (April 15, 2024 at 12:48 PM).
  • Everything seems to be working OK at the moment. I enabled the epg running state on my docker as well as disabling the Sky epg collector and deleting the epg grabber channels which had been created by the Sky collector, so only the Freesat collectors are running on that.
    I have left my Athlon 5350 system as it was with both enabled but have not enabled the 'running state'. I will have to post a question on the TVH Forum I think about how things work with regards to precedence, etc.
