Hello guys. I am a newbie and I want to Use an h96 mini remote control on a X96 mini. Can you guys help. Thanks
Use a h96 mini remote control on a X96 mini
issel -
December 17, 2023 at 10:13 PM -
Read: https://wiki.libreelec.tv/configuration/ir-remotes - If there's an existing keymap to reuse you can set it using the 'basic' config steps. If not you need to create your own via 'advanced' config steps (not complicated).
I don't think I can do it ( creating my own remote file). See I don't want to change my current interface atvxperience to Kodi. I found a my_remote.conf file in the forum I tried copying and pasting in etc\vendor but I couldn't.
It's not complicated and you can't break anything (worst case you delete a file and reboot to reverse changes). All it needs is some patience and initiative.
Ok friend thank you . Any idea where to start from? A link , a lesson ...
I put the wiki link in post #2
