LE11 Generic - Audio stuttering
  • Hi.
    My Problem:
    While playing a video or LiveTV, the Audio is stuttering in irregular intervals, while the video looks fine.
    Stuttering: The audio doesn't sound weird, it just mutes on and off stuttering for a few seconds every few minutes.
    My Hardware:
    • Asrock Beebox i5 7200u | 64GB SSD | 8GB RAM
    • USB-Soundcard: Creative Sound Blaster Play! 2
    • USB HDMI-CEC PulseEight Adapter
    • HDMI1: WimaxIT 14" FullHD
    • HDMI2: Samsung 50" TV (with CEC-Adapter)
    I didn't use it for some time, so i don't exactly know when it worked the last time.
    The problem occures independent of the video format. From SD AVI with MP3 to 1080p H265 AC3 5.1.
    What i tested so far:
    • Switching from LE11 Generic Legacy to LE 11 Generic.
    • Downgrading to LE10.
    • Complete new installation of LE Generic Legacy.
    • I tested it without the USB-Soundcard
    • I tested it with only the TV without CEC-Adapter
    • I tested it with only the 14" monitor.
    • I tested Audiooutput to Headphone, Tv and Monitor.
    • Almoust all gui settings regarding audio or video.
    • Increased Buffering to 4gb
    • changing cpu scaling governor to performance
    I'm currently running the latest nightly of LE 11 Generic Legacy. The only addon i installed is the TVHeadend Client. Disabling it makes no difference.
    Some observions:
    • cpu usage of kodi.bin increases from ~32 to ~100 while audio stuttering. (using ssh and top)
    • I think the problem increased after refreshing the video libraries (MyVideo121.db: ~250mb)
    Any Ideas?
  • No ideas?
    In the meantime I have tried the following:
    • Updated the BIOS and played with the settings -> no difference
    • Replacing the thermal paste for the CPU fan -> no difference
    • Installing LibreElec 9 -> no difference
    • Installing Windows 11 + Kodi -> The problem was even worse
    • Windows 11 + Kodi with VLC as external player worked fine. But is not a permanent solution
    • Tried other HDMI/DP cables
    Maybe a hardware defect?
