Selecting display / getedid help
  • Hey y'all!
    I'm trying to set up my Surface Go 2 as my HTPC and LE will not output to my TV. I am new to Linux in general so I may be missing something obvious here!
    From what I can see on this it look like the "getedid create" command should handle this automatically when running it via ssh, but it is returning "
    More than a single device connected. Probably enable "Disable all other monitors" at Kodi settings. Aborting! " . The closest I can find in Kodi is "blank other displays" and this is enabled already. The Surface has a pentium-4425y CPU with integrated graphics, and it is connected to the TV with a USB-C hub. Thanks in advance for the help!
  • Hello!
    As I said, I'm a COMPLETE newbie when it comes to Linux and editing boot files like this 😅. I followed the steps in this guide but put the adjustments in the line below I was supposed to, causing it not to work. This thread can be closed as I do not know how to do it. Thank you for your hard work!!!
    Resolution
