RK3328 4K HEVC stutter frame drop
  • hi, i'm using a Pine64 Rock64 (hardware supports 4K : .265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4Kx2K @ 60fps
    source : https://pine64.org/documentation/ROCK64/_full/#video
    I've installed latest stable LibreELEC image
    (https://releases.libreelec.tv/LibreELEC-RK33…0-rock64.img.gz)
    I've set resolution to 4K in preferences and in inputstream resolution to 4K too.
    I've made some tests on various HEVC 4K files , the screen is green kodi.log says :
    error <general>: CDVDVideoCodecDRMPRIME::FilterOpen - avfilter_graph_config:  Function not implemented (-38)
    I've also disable DRM PRIME green screen is not present but CPU is 100% and fps are very slow, so can't see video
    How can I play 4K 265 in Rock64 ?
  • error <general>: CDVDVideoCodecDRMPRIME::FilterOpen - avfilter_graph_config: Function not implemented (-38)
    This ^ is harmless and can be ignored.
    Forcing the default resolution to 4K won't help the GUI experience, see https://wiki.libreelec.tv/configuration/4k-hdr and follow the recommendations for setup including the whitelist. Correct config on all ARM SoC hardware is DRMPRIME enabled, HW decoding enabled. Then retest with a current LE13 nightly. If there's still an issue, put Kodi in debug mode, reboot and demonstrate the issue and then "pastekodi" to share the log.
  • I've read the documentation and make some changes, i still get green screen
  • Tsxop But is the green screen only when playing the video or always? It could be a bug in the HW decoder pipeline, Kodi or worse a 4K format nn supported via HW. Do other resolutions work?
  • Just for some 4K HEVC video.
    Here's some details about the file which cause problems :
    That one works well : https://www.libde265.org/hevc-bitstream…x2160-cfg02.mkv
    Yes 1080p is ok
    Edited once, last by Tsxop (October 4, 2025 at 7:22 PM).
  • Comments:
    a) The desktop resolution is 1080@60.
    b) The whitelist has been configured but the whitelist decision-tree (evaluating what mode from the configuration to use) is not visible when media is played and this normally means adjust-refresh and/or the whitelist are not enabled.
    c) The family-movie file is 3840x2160@25 but there is no 4K@25 mode in the whitelist or EDID data. This means Kodi cannot play media at its native rate or a 'double' of the native rate (4K@50) and must adapt the content. This does not give great results, and there is also no mention of a rate change in the log so it might be converting 4K@25 to 1080@60?
    d) The log does not show playback of the BBB file, but this media is 3840x2160@60 and there is a 3840x2160@60 mode available so Kodi will be able to output at the native resolution/refresh.
    e) The "Impossible to convert between the formats" error is unusual (first time that I see it) and I'm not sure where in code that comes from, but the mention of scaling also makes me think it might be trying to scale 4K@25 to 1080@60.
    f) EDID data shows "IIyama" which is a Monitor brand. If this is a monitor? using a TV with a full selection of modes, ensuring that adjust-refresh and whitelist are enabled and set correctly (as per the article I linked before) the results should be better. The EDID data shows 4K@25/50 and [email protected]/24/25/29.97/30 modes are missing; although enabling rate-doubling means the 25/29.97/30 modes can match with 50/59.94/60. The lack of [email protected] mode means HD movies must be CPU scaled to [email protected] and this can impact overall device performance.
    g) If this is the only screen you have, download Handbrake and convert the problem files to 4K@30 and they should play better on a device that has a 4K@30 (and 4K@60) mode. Configure the phone? to use 4K@30 and then future movies don't require you to convert them with Handbrake.
    TL/DR: Monitors make rubbish TV's /shrug
  • Comments:
    Yes the resolution is set to 1080@60 manually fixed in kodi's settings
    I can see in yellow every 1920x1080 and every 3840x2160.
    I've also checked bellow whitelist 'Allow refresh 3:2 pulldown' and 'Refresh twices' in Whitelist section.
    I'm pressing o to see information the video is 3840x2160@25 but the video is adapted to 1920x1080 at the screen
    Ok
    The monitor is IIyama ProLite XB3288UHSU which
    Native resolution3840 x 2160 @60Hz (8.3 megapixel 4K UHD)
    source : https://iiyama.com/gl_en/products/prolite-xb3288uhsu-b5/
    I've also : Set the Adjust Refresh setting to "On Start/Stop"
    This is the only screen I have.
    I'm playing videos by using Kodi interface, how can I configure to use 4K@30 ?
  • There is no magic Kodi configuration that will fix this problem on your hardware. The three solutions are:
    a) Use a monitor or TV that has the required 4K@25 or (doubled) 4K@50 refresh rate so the RK3328 board can play media at native refresh rates without needing CPU conversion to 4K@60 or 1080@60 that a low-spec ARM SoC chip cannot handle.
    b) Use high-spec hardware that can handle the required CPU conversion to 4K@60 or 1080@60.
    c) Convert problem media (offline, using Handbrake) from 4K@25 to something that matches monitor modes, i.e. 4K@30 so the low-spec ARM SoC hardware can play media at native rates (as with the BBB file).
