Hi, maybe take a look here.
Another device, another issue... I'm using LE with RPi, in the case when the RPi restart, when the TV is in standby, had EDID issue, so I made an EDID dump with "getedid create" command. Something similar you can try... If you can save your TV's edid data with another device and put it in the right place in your Wetek?
