Help disabling internal wifi on X96Air
  • Hi all,
    Since the last few versions of coreelec my onboard wifi basically sucks. Lucky to get 1Mb/s.
    I have a USB WIFI adapter which i have put in. The thing is depending on the way it boots its sometimes wlan 0 and sometimes its wlan 1
    According to running this command this is the drivers
    CoreELECx96Air:~ # readlink /sys/class/net/wlan1/device/driver
    ../../../../../../../bus/sdio/drivers/rtl88x2cs
    CoreELECx96Air:~ # readlink /sys/class/net/wlan0/device/driver
    ../../../../../../../../bus/usb/drivers/8812au
    So i added this to my blacklist.conf
    blacklist rtl88x2cs
    Rebooted and still both are showing up
    here is my dmesg
    http://ix.io/4FTz
    My Lsmod is shown
    Module Size Used by
    hidp 32768 0
    meson_remote 57344 0
    rfcomm 53248 6
    hci_uart 77824 1
    btqca 16384 1 hci_uart
    btbcm 16384 1 hci_uart
    btintel 24576 1 hci_uart
    bluetooth 385024 37 hidp,hci_uart,btintel,btqca,btbcm,rfcomm
    8822cs 2519040 0
    8812au 1740800 0
    mali_kbase 462848 3
    openvfd 192512 1
    nfsd 327680 3
    exportfs 16384 1 nfsd
    nfs_acl 16384 1 nfsd
    wireguard 118784 0
    ip6_udp_tunnel 16384 1 wireguard
    wifi_dummy 16384 0
    amvdec_vp9 139264 0
    amvdec_av1 172032 0
    amvdec_vc1 77824 0
    amvdec_real 49152 0
    amvdec_ports 163840 0
    v4l2_common 16384 1 amvdec_ports
    videobuf2_dma_contig 20480 1 amvdec_ports
    videobuf2_memops 16384 1 videobuf2_dma_contig
    v4l2_mem2mem 24576 1 amvdec_ports
    videobuf2_v4l2 24576 2 amvdec_ports,v4l2_mem2mem
    videobuf2_core 45056 3 amvdec_ports,v4l2_mem2mem,videobuf2_v4l2
    amvdec_mpeg4 73728 0
    amvdec_mpeg12 131072 0
    amvdec_mmpeg4 49152 0
    amvdec_mmpeg12 53248 0
    amvdec_mmjpeg 32768 0
    amvdec_mjpeg 45056 0
    amvdec_mh264 184320 0
    amvdec_h265 176128 0
    amvdec_h264mvc 61440 0
    amvdec_h264 167936 0
    amvdec_mavs 61440 0
    amvdec_avs 81920 0
    amvdec_avs2 233472 0
    stream_input 208896 13 amvdec_h265,amvdec_mavs,amvdec_mh264,amvdec_h264mvc,amvdec_av1,amvdec_ports,amvdec_real,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_mmpeg12
    decoder_common 245760 19 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_av1,amvdec_mmjpeg,amvdec_ports,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
    firmware 28672 19 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_av1,amvdec_mmjpeg,decoder_common,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
    media_clock 40960 17 amvdec_h265,amvdec_mavs,amvdec_mh264,amvdec_mmpeg4,amvdec_av1,amvdec_mmjpeg,decoder_common,amvdec_ports,firmware,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mpeg4
    video_framerate_adapter 16384 1 decoder_common
    amlvideodri 20480 0
    videobuf_res 16384 1 amlvideodri
    videobuf_core 28672 2 amlvideodri,videobuf_res
    videodev 270336 6 amlvideodri,v4l2_common,amvdec_ports,videobuf2_core,v4l2_mem2mem,videobuf2_v4l2
    media 36864 1 videodev
    fuse 114688 1
    fbcon 57344 0
    bitblit 16384 1 fbcon
    softcursor 16384 1 bitblit
    font 20480 1 fbcon
    Can anyone assist?
    Edited 2 times, last by andymarc (September 10, 2023 at 6:59 AM).
