[RPi4] Argon One Case Shutdown
  • I am quite sure, that after update I haven’t opened add-on settings.
    I think that new configuration parameter was not stored in config file and this caused my issue.
  • I was able to find 2 possible causes for the reported switch-off problem. Both situations can be prevented/fixed if the settings dialogue of the add-on has been closed once with OK (this will create/update the required settings.xml). I will provide an updated version of the add-on to fix the problem permanently.
  • Version 1.1.10 released:
    • regression: shutdown does not work properly if the settings.xml file is incomplete or missing
    This should fixes the issue reported by Gwin. The PRs have been created to provide this version via LibreELEC add-ons repo as well.
