I tried to set subs key to search subtitles with keymap editor, by clicking edit - > global - > windows - > open subtitles search. And it didn't work. Didn't find this command at subtitles secession.
LibreELEC 8 for K1 plus DTV button on the remote control = null .... LibreELEC 7 for K1 plus DTV button = GUIDE (TV)
How to DTV button = GUIDE --> LibreELEC 8
Hi people! Does anybody know if KIII PRO actually can run libreelec? KIII PRO OTT
It has a S912 and 3gigs of RAM, looks good
I was to buy the KII Pro but I found this and make me doubt
No support for s912.
have to say that , what about to leave button mappings tvh settings etc to their own threads? or sites.
subs button doing something else, or i want change button action, have nothing to do with build or image.
tvh settings detto
usb port not working or keys on remote mean number buttons on kII, thats what alf, kszaq could change.
- deleted -
Succeed to set dtv button to do subtitles search with keymap editor.
After a while i tried again the latest version from le to my k1plus with the latest k1plus and the linked tvheadend version.
The scan work for dvb-s, and the dvb-t stick, but i have problems when i stream the channels. Many buffering issue has i especially with hd stream.
The second problem: oscam not work with dvb-s tuner together.
AGAIN!!!
Please, double check your installation! Upgrade addons from LibreELEC repository to the latest version.
I tested tvheadend 8.1.109 (4.1.2415) + oscam 8.1.103 (11350).
My builds strictly are following kszaq's builds adding only internal driver. Now I am testing vesion with public internal driver fully compatible with latest kszaq's build. I'll publish this version with full source code.
AGAIN!!!
I tried with this version:
"- latest service Tvheadend42 is broken. Install fixed version service.tvheadend42-8.1.108.zip and disable auto-update."
Because in the first post this is the recommended version.
I try with the latest version now.
Come back after an hour.
I try scan with tvheadend 8.1.109 (4.1.2415)
Every channel say this the tvh log:
2017-02-01 15:35:15.367 linuxdvb: Realtek RTL2832 (DVB-T) : DVB-T #0 - DTV_CLEAR failed [e=Inappropriate ioctl for device]2017-02-01 15:35:15.367 mpegts: 562MHz in DVB-T - tuning on Realtek RTL2832 (DVB-T) : DVB-T #0
2017-02-01 15:33:37.029 linuxdvb: Availink AVL6862 : DVB-S #0 - DTV_CLEAR failed [e=Inappropriate ioctl for device]2017-02-01 15:33:37.029 mpegts: 12245H in Thor - tuning on Availink AVL6862 : DVB-S #0
And only the dvb-s internal tuner detected, and the plugged usb dvb-t tuner.
AGAIN!!!
Have we any news about dvbc anx b?
So with new version 8.1.109 scan is stuck, with old version scan ok, but no playback paytv. TV without encryption played. Something stucked between oscam and tvh
tvh log:017-02-01 16:43:56.653 subscription: 0056: "127.0.0.1 [ admin | Kodi Media Center ]" unsubscribing from "RTL+", hostname="127.0.0.1", username="admin", client="Kodi Media Center"2017-02-01 16:43:56.655 mpegts: 12034.36V in Thor - tuning on Availink AVL6862 : DVB-S #02017-02-01 16:43:56.679 capmt: Oscam: Starting CAPMT server for service "RTL Klub HD" on adapter 02017-02-01 16:43:56.680 subscription: 0059: "127.0.0.1 [ admin | Kodi Media Center ]" subscribing on channel "RTL Klub HD", weight: 150, adapter: "Availink AVL6862 : DVB-S #0", network: "Thor", mux: "12034.36V", provider: "UPC Direct", service: "RTL Klub HD", profile="htsp", hostname="127.0.0.1", username="admin", client="Kodi Media Center"2017-02-01 16:44:04.772 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:04.772 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:05.742 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 1)2017-02-01 16:44:05.904 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:05.908 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:15.824 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 10)2017-02-01 16:44:25.993 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 15)oscam log
and with the same settings ( i checked many times, and later try copied oscam from userdata/addondata folder from my wetek) with my wetek play it worked without problems
With wetek play:
work flawlessly
Something problem is with tuner driver or tvheadend.
I guess tuner driver problem, because with dvb-t stick work encrypted stream, only with dvb-s not.
Without encryption work the dvb-s tuner, so i think something is here with pid's lost with tuner.
With wetek play and libreelec 7.0.3 with the same settings work everything.
tvheadend 4.2 7.0.102 4.1.1945
oscam 7.0.101
New driver has DVB-C annex A, B support. But I have no chance to test it. I am still fixing it, now only DVB-T is running.
Display More
- 2017/02/01 16:46:46 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:46 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:49 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:52 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 1 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:46:52 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:53 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:56 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 0 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:02 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:05 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 1 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:47:05 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:47:06 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:09 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00F
With wetek play:
- dvbapi) Demuxer 0 ecmpid 0 CAID: 0653 ECM_PID: 1868 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0D97 ECM_PID: 173C PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0B02 ECM_PID: 14E4 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1815 ECM_PID: 13B8 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 found 4 ECMpids and 1 STREAMpids in caPMT
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0D97 PROVID 000000 ECMPID 173C ANY CHID PMTPID 0000 VPID 01C3
- 2017/02/01 19:00:47 3ADBD4DD c (dvbapi) Demuxer 0 found 4 ECMpids and 2 STREAMpids in PMT
- 2017/02/01 19:00:47 3ADBD4DD c (ecm) anonymous ([email protected]000004/0000/7664/B8:0E204470B0CC76B8DDC0057DC6CF88EB): found (339 ms)
work flawlessly
oscam 7.0.101
I double checked 7.90.beta3 and the latest tvheadend42 + oscam from kszaq's repository have no problem to descramble encrypted channels.
There was tvheadend issue after moving v4l2 support to media_build but it is already fixed by kszaq.
The funny thing is that I have no idea how I fixed this but I'm glad it's working for you now. [emoji2]
You mean, the 109 version?
that for me breaked at the first scanning.
no scan. Every tuner has scanning problem (USB dvb-t too)
And no dvb-t tuner (own), no dvb-c tuner.
the 108 work with :
-free dvb-t (USB stick)
-pay dvb-t (usb-stick)
-free dvb-s2
and not work:
-pay dvb-s2
I install twice both the 108 and 109 version, make twice clean install, try copy from wetek Userdata/addondata the tvheadend and oscam settings, always the same result.
between trying I put back sat plug to wetek,and turn on for try and controlled settings.
with wetek everything work.
here is always continuity problems at tvh log with encrypted sat programs. I think not given the necessary ecm,... Pids to oscam, and thank for this oscam not work.
I have the same situation on KII Pro.
Crypted dvb-s channels don't work, the others are OK.
I can add that I have this problem after I remove the USB dvb-t tuner and manage tvheadend to add a iptv. This evening I'll reconnect the external tuner I'll try with internal dvb-s cripted channels.
Then you havent setupd something fine.
All works normal.
Display MoreYou mean, the 109 version?
the 108 work with :
-free dvb-s2
and not work:
-pay dvb-s2
Yes, I went back to v108 (from post #1) after similar issues.
