5.1 Sound not working with X-FI 5.1 USB on rPI3
    I have a problem with LibreELEC 7.0.2 on my rPI3 that has Sound Blaster X-Fi Surround 5.1 Pro USB connected to it. When I switch from 2.0 to 5.1 there is no sound for movies with AC3. This works ok with OpenELEC 6.0.3. I use analog connection from USB card to Logitech 5.1 speakers. When it is set to 2.0 it works. How can I fix this to use 5.1 surround sound like on OpenELEC 6.0.3?
  • I currently have OpenELEC installed but my settings were (same as OpenELEC):
    Audio output device: Creative X-FI 5.1 Pro (ALSA:@:CARD=Pro,DEV=0) analog
    Number of channels: 5.1
    Output configuration: Optimized
    Stereo upmix: un-checked
    Normalize levels on downmix: checked
    Resample quality: High
    Keep audio device alive: 1 Minute
    Play GUI sounds: Always
    Enable passthrough: un-ticked
    Settings are default, the only thing that I changed was "Audio output device -> Creative X-Fi analog" and "Number of channels -> 5.1", but this worked for me on OpenELEC.
    This settings are from OpenELEC:
    <audiooutput>
    <ac3passthrough default="true">true</ac3passthrough>
    <ac3transcode default="true">false</ac3transcode>
    <audiodevice>ALSA:@:CARD=Pro,DEV=0</audiodevice>
    <boostcenter default="true">0</boostcenter>
    <channels>8</channels>
    <config default="true">2</config>
    <dtshdpassthrough default="true">false</dtshdpassthrough>
    <dtspassthrough default="true">false</dtspassthrough>
    <eac3passthrough default="true">false</eac3passthrough>
    <guisoundmode default="true">1</guisoundmode>
    <maintainoriginalvolume default="true">true</maintainoriginalvolume>
    <passthrough default="true">false</passthrough>
    <passthroughdevice default="true">PI:HDMI</passthroughdevice>
    <processquality default="true">30</processquality>
    <samplerate default="true">48000</samplerate>
    <stereoupmix default="true">false</stereoupmix>
    <streamsilence default="true">1</streamsilence>
    <supportdtshdcpudecoding default="true">true</supportdtshdcpudecoding>
    <truehdpassthrough default="true">false</truehdpassthrough>
    </audiooutput>
    Configuration from LibreELEC:
    <audiocds>
    <autoaction default="true">0</autoaction>
    <ejectonrip default="true">true</ejectonrip>
    <encoder default="true">audioencoder.xbmc.builtin.wav</encoder>
    <recordingpath default="true"></recordingpath>
    <trackpathformat default="true">%A/%A - %B/[%N. ][%A - ]%T</trackpathformat>
    <usecddb default="true">true</usecddb>
    </audiocds>
    <audiooutput>
    <dspaddonsenabled default="true">false</dspaddonsenabled>
    <processquality>101</processquality>
    <supportdtshdcpudecoding default="true">false</supportdtshdcpudecoding>
    </audiooutput>
    <bluray>
    <playerregion default="true">1</playerregion>
    </bluray>
    <cache>
    <harddisk default="true">256</harddisk>
    </cache>
    <cacheaudio>
    <dvdrom default="true">256</dvdrom>
    <internet default="true">256</internet>
    <lan default="true">256</lan>
    </cacheaudio>
    Edited once, last by Luka (November 29, 2016 at 12:00 PM).
  • Found the problem! Under settings I have accidently turned Resample quality to GPU audio acceleration instead of High. Using High, medium or low now works with 5.1.
