hello everyone, i have raspberry pi 4 with libreElec OS , i have installed ngrok, and i want to run ngrok at startup in background.
howTo do this?
libreelec v19.5 stable
v10.0.4
RPi4.arm
any information missing? let me know
howTo do this?
v10.0.4
RPi4.arm
You can add a systemd service file in /storage/.config/system.d to execute commands
Or create a /storage/.config/autostart.sh script containing the startup command.
ngrok would probably have dependencies on networking so systemd would always be the better approach since you can sequence the start to happen after the network is up/online.
so if i want to add this at startup
./ngrok tcp 22
i would create a file in system.d folder
name it ngrok.service.tunnel
now what do i input in this file? only the command like this?:
./ngrok tcp 22
and keep the rest of the file empty?
or i need more information?
after this i would do a reboot and it would start automaticly at every boot unless i do upgrade/downgrade OS?
thanks you all for helping
[Unit]
Description=ngroc service
After=network-online.target nss-lookup.target time-sync.target
Wants=network-online.target nss-lookup.target time-sync.target
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/path/to/ngrok tcp 22
[Install]
WantedBy=multi-user.target
Display More
^ something like that in /storage/.config/system.d/ngrok.service
Then "systemctl enable /storage/.config/system.d/ngrok.service" and "systemctl start ngrok.service" .. it should then be persistent over restarts and even upgrades (as long as ngrok itself continues to run).
this is my ngrok.service file:
[Unit]
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/storage/ngrok tcp 22
[Install]
Any more info i need to edit?
see image for error:
i got this new folder named multi-user.target.wants containing the link to ngrok.service
i tried running systemctl status ngrok.service but the output was too much for my ssh client on my iphone.
thanks for all help
why image error didnt show earlier:
i think i added attachment from photos and then i choose full image so it appeared in my comment and then i deleted the attachment because i tough the attachment and full image would mean double images..
Link to error message doesn't work. Please edit your post.
maybe i could use zerotier , any way to install zerotier to my setup?
maybe its an addon?
anyone
