Dear LE team,
So happy to get LE11 support for our good/old Wetek Hub, I installed AMLGX wetek Hub box image to flash.
Following the wiki page, I booted the 'box' image from SD card, then used emmctool to write the 'wetek-hub board' image to eMMC.
(I had to first 'zero' the eMMC because emmctool did not like the labels on it).
But now on boot, I can see from the serial port that the boot process stops halfway (console log below).
if I type 'boot' on the uboot prompt, it will continue and complete booting, and I get LE running just fine...
Any idea how to make boot complete at once?
Thanks!
QuoteDisplay MoreGXBB:BL1:08dafd:0a8993;FEAT:EDFD718C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0;
no sdio debug board detected
TE: 117751
BL2 Built : 09:01:42, Oct 11 2016.
gxb g88b04d6 - haixiang.bao@droid05
set vcck to 1100 mv
set vddee to 1000 mv
Board ID = 1
CPU clk: 1536MHz
DDR chl: Rank0+1 same @ 912MHz
DDR0: 1024MB(auto)-2T-13
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000d460
Sending bl30......................................................OK.
Run bl30...
Load bl31 from eMMC, src: 0x00020000, des: 0x1010[000, size: 0x00018190
Image: gxb_v1.1.3135-18177fc 2016-06-24 11:00:09 yun.cai@droid06]
OPS=0x13
7d e0 7e 24 97 14 ac a7 7d 21 38 a3 [0.203101 Inits done]
secure task start!
high task start!
low task start!
Load bl33 from eMMC, src: 0x0003c000, des: 0x01000000, size: 0x0008ecf0
NOTICE: BL3-1: v1.0(debug):bc3419d
NOTICE: BL3-1: Built : 14:16:22, Aug 15 2016
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
<debug_uart>
U-Boot 2022.10 (Feb 27 2023 - 22:22:07 +0000) wetek-hub
Model: WeTek Hub
SoC: Amlogic Meson GXBB (S905) Revision 1f:c (13:1)
DRAM: 1 GiB
Core: 161 devices, 25 uclasses, devicetree: separate
MMC: mmc@70000: 0, mmc@72000: 1, mmc@74000: 2
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
[BL31]: tee size: 0
Net: eth0: ethernet@c9410000
Hit any key to stop autoboot: 0
