LibreELEC doesn't start after the first installation
    I've just installed LibreELEC x86_64-10.0.4 on my thin client Fujitsu S740 (Intel Celeron j4105/Gemini Lake/Gen 9.5)
    Unfortunately LibreELEC can't boot.
    During instalation I seleted 8GB SATA SSD disk to install LibreElec system.
    Unfotunately I can't see this HD disk when I want to select it (in the BIOS) as bootable disk.
    Fujitsu S740 has only UEFI BIOS.
    EDIT:
    I've tried to install the newest nightly build 'LibreELEC-Generic.x86_64-11.0-nightly-20230126-52cf225'' but it didn't help.
    Still after installation my system doesn't recognize internal 8G m.2 SATA bootable disk.
    See log:
    20230127072420.log - Pastebin.com
    Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
    pastebin.com
    What can i do to move on?
    Edited once, last by bern (January 27, 2023 at 8:01 AM).
  • From a web search your Fujitsu S740 seems not to boot from /EFI/BOOT/BOOTX64.EFI of the internal disk by default.
    Unfortunately efibootmgr to set an EFI boot entry is not part of the installer image.
    Is there a menu in the UEFI BIOS to create boot entries?
  • Is there a menu in the UEFI BIOS to create boot entries?
    Thanks for replay. Yes I can select bootable disks and put them in desired order. I can also use F12 key to call boot menue during startup.
    Today I experimented a bit and I took this M.2 SSD out and put it in the M.2 to USB 3.1 adapter and after instalation I can sellect this disk as bootable. It works but it is inconvenient. I'd rather have this SSD inside.
  • There is a community User Guide for the Fujitsu S740. Unfortunately in German, you may have to use a translation service.
    The original links of the following line shows the Linux boot problem:
    - Linux bootet nicht? Booteintrag muss manuell angelegt werden (1, 2, 3, 4, 5, 6)
    Thanks for providing a source of valuable information for my hardware.
    I was able to find a solution to boot issue.
    I installed LibreElac normally (on my SSD) and then booted from GParted Live on USB.
    I opened the terminal and used a command:
    sudo efibootmgr -c -d /dev/sda -p 1 -l '\EFI\BOOT\bootx64.efi' -L "LibreELEC"
    After a reboot LibreElac boots from SSD normally.
    Edited once, last by bern (January 29, 2023 at 1:54 PM).
