Hi folks,
I've got a strange issue with LibreElec on a couple of Wetek Play boxes that I'd appreciate help with.
The problem started when I tried to install Seren on one of them, which failed due to a failure to install dependencies.
Looking into it further it appears that the dependencies which are failing are in the Kodi Add-On repository, which on these devices seems seriously old (v3.1.5) compared to one of my other Kodi boxes.
When I try to update or install anything in the Kodi repo it fails.
The log is showing errors with SSL certificates amongst other things.
Both boxes are running 9.0.2
Log file is here: http://ix.io/4fP2
I've tried resetting LibreElec to defaults but that hasn't affected the situation.
Both boxes have exactly the same issue.
Any help greatly appreciated!
